My dat file is not opening completely,the airfoil is broken at the end(not joined)
the plot is not joined in the end....if I use sketching for joining it isnt joining...please help.....if you can manipulate the data file for plotting please do help(stuck for 3 days)
it's a Boeing 737 200 airfoil
You’re doing it correctly. It’s normally open at the end. Airfoils must have some finite thickness at the trailing edge. In actual construction they never taper to a knife edge. Just place a short line segment connecting the upper and lower surface together.
What is the airfoil number? There are constants that are sometimes modified to produce a closed trailing edge. For instance in a NACA 4-digit airfoils the fourth term (a4) in the equation is changed from -0.1015 to -0.1036 for a closed trailing edge
