my trim tool is not activated why????
hi guys, my trim tool appears grey i mean it is not activated or i dont know whats the reason it does not work, please please help its my final proyect, i am studying mechanical engineering, thanks a lot.
Hi, I am guessing you mean the 'Trim Surface' tool? This will be because you don't have any surfaces in the model! The only feature is a solid loft- if you were to redo this as a surface loft you should have the trim function available to you.
Cheers,
Shaun
