Need help for technical drawing for my step file!
I need help regarding this step model. It was a one of the component I am using in my project. I am having trouuble with exact extraction of technical drawing.
Please create a manufacturing drawing for my step file. I would like to understand what all I should be included in this technical drawing so that it would be suitable for ordering the detail. The Material I considered is EN AW-6082-T6, and the manufacturing method is milling.
Here are some requirements I prefer:
- Hole patterns marked with orange are threaded, hole pattern marked with blue is a through-hole. Thread dimensions can be derived from the hole size.
- The horizontal (according to the isometric view ) surfaces parallelly (excluding the ribs) is important
- GD&T is encouraged
- Threaded hole positions are important
- Three not threaded holes positions from each other are important. Also, the position from the parts centre is important
- The outer diameter of the part is important
- The curved shape going through the part is important
What is stated as important should be toleranced. Tolerances should align with the manufacturing method.
Please have a look at it and help me with the technical drawing!
I appreciate your help.
Thank you.
