Negative value on Beam analysis
Hi guys,
I`m running an analysis on a structure using Channels, and i regard them as beam because i`m facing trouble when i treat them as solid bodies as the meshing keep failing and no results are appearing when i run them. Surprisingly when i treat them as beam it meshed smoothly and there is results after i run the study. However it came up with negative value as min in the chart and i did not how to interpret that value as what. Please kindly advise. Thank you in advanced.
