Not able to do 2 multiple embossing on a cylindrical surface.
I'm trying to emboss some design on a cylindrical surface. But for some reason, I can only emboss it once
(on area of the curved surface visible from front view ). Whereas i wan to emboss it on the back face also(on area of the curved surface visible from back view )
Easiest thing to do would be to offset a workplane the same distance to the other side of the part. Then use project geometry of the sketch over to the other workplane from your existing sketch. Then you can emboss again to the other side like you want to do.
