Missing feed
not registring contact between two bodies
By Ksenija Vasiljeva on 12 Aug 11:37 3 answers 0 comments
Hello, I have two bodies rolling against each other, I set up contacts of the bodies, but whenever I run the analysis it is not registering the contact and bodies go through each other. Could there be a bug in SolidWorks 2012?
  • Rob
    Rob about 2 years ago
    Try upping the Frames per second to 120 fps or greater.
  • kucara
    kucara about 2 years ago
    you have problem in the bodies. If you give some pictures will be easier to help you. You can also add 3d model to see what is the problem
Add your answer to: "not registring contact between two bodies"
