Please help....I have some errrors in NX8 installation..
NX8 was succesfully installed in my pc....but i have some problem...
(Failure in XERCES_SAX_parse attempting to parse file:
FILE:///C:\Program files
(x86)\ugs\ugii\materials\physicalmaterialdefinition.xml)
this warning disturbed to run the program...any solutions here...??????
Comments 3
hi
first you sat up win 7 (32 bit) operating
then it is easy to NX 8.0 install for you.or
add me in skype for more "nximran" is my id
ok ........
for me also same problem in 32 bit only.can u pls send ur file in prog files dirctry from that we will try
i have nx8 win 64 bit installed sucessfully but it is not running showing ugraf.exe application error .......what should i have to do to run nx8?
did you find solution
for this problem ????
