pls help me to solve this proble.when am opening a catia file having one geometric set inside it.it is going far away from the axis system.how can i make that component(which is inside the geometric set)origin to axis system origin?)
i have uploaded the cati.part file here.pls help me
thanks in advance
You can use Translate and Rotate commands to move the part to the origin. I moved it for you in the file.
