pls tell me how to get snapshot pro-e 05???
i wnt to take snapshop for this assembly
View > Model setup
from there choose your scene, lights, orientation .... etc.
when you are happy with your model and you want to render it go to view > Render Window. to save it go to file > save a copy > JPEG or PNG or whatever format you want.
to change the rendering quality and the output image resolution go to View > Model setup > render setup
Play with it, it is not complicated, you should be able to fine your way through.
Comments 2
either use the print screen option on your keyboard.
Or use ProE's Rendering engine...
1) If u r using windows 7 use snipping tool it solves u r problem.
2) In pro e go to file>>save a copy select jpg format
