Problem on savenig STP file in CATIA V5
I found a surface with IGS format, and I convert it to a Solid model using "Close Surface" command (in Part Design). Finally I save it as STP file, but when I open the STP file in CATIA, it appear as surfaces and there is no Solid Model (like saving a model in IGS format, see pictures).
why this Problem occur and what is the solution?
Regards.
Hi,
copy the solid and paste it "as result" in a new part.(no reference for this solid still exists) Then save this part as STP file.
Regards
Hello,
I am using v5 r20,.step format files it is difficult to open and am getting problem like all parts list shows in specification tree but actual part visibility is missing.
Please advise.
STEP FILE FORMAT CONVERSION ALWAYS CAUSE MORE TROUBLES,
X_B OR X_T FORMAT ARE MORE RELIABLE AND PRECISE.
steps for saving STp file
1. Save as .IGS format
2. Close the current window
3. Open the .IGS format file by dragging it into new CATIA V% window
4. Now Save as .STP format
There should not be any problem.
You can select .stp format while saving.
Could you give some more details about your problem?
