problem with kinematics
as cyou can see on picture i have got 4 belt connection on assembly. problem is that i started to assemble exhaust valve on right side. firt 2 valves which i gave to the assebmly and made CAM mate with camshaft are good all assebmly works i mean if i spin crankshaft all belts work. but if i give other valves to the assebmly i causes that assembly dont work that mena crankshaft and left camshaft dont spin..
Cam anybody tell me how i can assemble this assembly with full kinematic i havent clue anymore...i spent on it 2 mounths doing it but i havent clue. or does anybody know about some online learning course?
god blees you for you help
Hi,
I tell you must send this model if you want help. I must check this, all mates, connections, model etc.
