Problems with PhotoView 360.
Let me know that I should have stopped working suddenly PhotoView 360. It has always done well, now I proceed to render, done as it will make opening and closing windows and nothing.
Thanks in advance and greetings.
I had the same problem. The problem was due to Bonjour Service. I accidentally uninstalled Bonjour service.
Check if bonjour service is installed and running. If you don't have setup https://support.apple.com/downloads/Bonjour_for_Windows
Photoview is giving me headaches. It worked as it should up to a few weeks ago, ever since, it opens up and closed right away.
- I have reinstalled bonjour many times over to no avail
- I've reinstalled Solidworks itself a few times without effect.
- I've reset the key registry to try and open it as factory reset, didn't work either.
- I've installed a different virusscanner (Eset to Norton) because I had a feeling that one removed or "quarantined" photoview files.
I have no idea what else I've tried but I feel like I've tried everything I could find online.
Anyone who knows what else I could try?
Thanks a lot in advance.
