Render problems with photoview 360 in soldiworks
after closed photoview360 and reopen it final render isent the same appearances in motioun study part
i want to create photoview360 rendered video
Varand - make sure that you have PhotoView 360 active. If PV 360 is active when you save your video a second option is available in the Renderer drop down window. The two options are "SolidWorks screen" and "PhotoView". Chose PhotoView from here to produce high quality PV 360 rendering in your video.
ok this problem is solved by deleting object and mate in last assemble part but have other problem in rendering part
http://grabcad.com/questions/pv360-render-problem-black-space
