RUNNING BELT , HOW I CAN DRAW A RUNNING BUILT THAT HAS CUTS IN?
Dear All ,
Am trying to make a running conveyor belt since 3 hours, i draw the rollers 2 pcs, 3 mtr distance then i insert the chain belt function , then i modefy the belt to be a part , i mate the belt with the rollers , then i add the box , then i make contact box with both roller , and box with the belt , even i change the material , to rubber , and i try to make cuts in the belt to see if it is moving , the rollers was moving togother ,
but my box stand in its please ..... so if some one Know the prcedure inform me .
thanks
I do it , by touching the box to the cylinder that the motor applied on. and the assembly is done .
