Searches inside GRABCAD return "No results :-( " yet EXTERNAL Google searches successful
Guys -
Searches inside GRABCAD return "No results :-( " yet EXTERNAL Google searches using the very same query preceded by the term "grabcad" return multiple results INSIDE GRABCAD . While I can go outside GRABCAD for each search, seems an extra unwelcome step. With GRABCAD being the FINEST RESOURCE ON THE WEB for much needed individual assembly components, this seems a bit of a speedbump ? Thanks - C. Fee - Independent Product Designer, Houston, Texas.
Lucious R.B. - Thanks for trying. All the best to you and yours, -C.
Charles what is the search term you used? We can take a look and see what is going on. Thanks!
Comments 2
Not a perfect result, but for troubleshooting try "gentry" as the search term.
GrabCAD shows two results by Billy Gentry: https://grabcad.com/library?page=1&time=all_time&sort=recent&query=gentry
Google also shows a Gentry Girder: https://www.google.com/search?q=grabcad+gentry&oq=grabcad+gentry&gs_l=psy-ab.3..33i160k1.64320.65587.0.65697.6.6.0.0.0.0.254.577.0j2j1.3.0....0...1.1.64.psy-ab..3.3.577...0j0i22i30k1.8exKbQUNxXA
Along with results for users Gary, and Cydnee as well.
10 ton d.g crane with gentry girder
Granted, it is likely meant to be a Gantry Girder. But the results are interesting.
Thanks for the Prompt response Grant.
is some other sites to get free step files , most free is cad date or revit
