shaft rotation along with bearing problem
By sarpabhushan torgal on 09 Jun 05:15 2 answers 4 comments
In assembly of shaft and bearing , if shaft rotates bearing also rotates in solidworks how to stop bearing outer case rotation
shaft assembly.SLDASM, 858 KB
Download
belvel gear shaft.SLDPRT, 233 KB
Download
  • Shafe Mohammad
    Shafe Mohammad 10 months ago
    SHAFT SHOULD BE IN 1 PART BEARING ASSLY IN ONE PART THEN GIVE RELATIONSSHIP
Add your answer to: "shaft rotation along with bearing problem"
