Solidworks file seems to be meshless and I can't convert it, PLEASE HELP.
I can't for the life of me tell you what's wrong with the file besides two things, in Solidworks I can't export the file to something like .stl or .amf for Solidworks believes that the object has improper geometry and the other is that I can't edit the file, I can't even select the object in Solidworks If someone could help I would really appreciate it. The file is not mine but I can send a link, Tippman TMC Stock Plug.
It's not a SOLIDWORKS file. Someone imported an STL file as a graphic image, then saved it as a SW model.
Best you can do is create a new model around it.
