Solidworks Stress analysis on retractable pipe assembly in concrete
Hello,
Have a pipe weldment assembly that can be retracted in and out ground mechanically. The pipe weldment is reinforced by concrete and rebar surrounding it.
Have all material properties assigned to parts. Need help on how to do stress analysis when a vertical load is applied to top of assemblly(24000lbs). Tried to run simulation express but it says it cannot do it on assembly.
could you please refer the drawing of your Assembly!!
