Star.exe has stopped working - cosmos problem
I'm trying to do a sheet metal simulation but whenever i set up the restraints, forces, mesh etc and i start to run the static study, i get a damn error: Star.exe has stopped working. Any idea what could cause this to happen?
In version 2010 was problem with global contact set. If you have global contact set on "no-penetration" this error come up. That was fix in 2010 PR1 version. Try to change global contact set and maybe that will help.
i found a solution, this is a folder permission issue. Check your folder permission and give full control to the folder, and delete temp files of simulation and run the simulation again. Cheers!
