SYMMETRY text upside down.
The problem is this, I make an extrusion with text and when I make a symmetry to the other side, the text makes me backwards. I do it from part. Is there no option that allows you to put it right ?. AutoCad is the MIRRTEXT command with 2 options and within SolidWorks assembly is the option to create symmetry version, which you do symmetry that interests you.
Attached pictures to clarify something else.
Image 1: symmetry from assembly.
Image 2: symmetry where I put the text upside down dede piece. (without options)
Image 3: Operation extruded text.
Image 4: extrusion operation symmetry text upside down.
http://i.imgur.com/z6Qp6NZ.jpg?1
http://i.imgur.com/9CQ8MCj.jpg?1
http://i.imgur.com/Jr5D4Wn.jpg?1
http://i.imgur.com/XqnptWs.jpg?1
Maybe you can use a circular pattern with 2 instances at 360 deg. using an axis on the center of the part.
Hello Mallias, would need a graphic example because it is not clear. By doing symmetry text mirror effect left out and want to leave as the right
http://imgur.com/Nic8Gid
http://we.tl/mQW2y3j9NF
