To use the command part massprop mass fraction of AutoCAD program How can I change the weight of the original?
By Hakan Kcksrklk on 19 Apr 08:29 1 answer 2004 views 0 comments
Autocad
Added images
Square
1 answer
  • samma noor
    samma noor almost 4 years ago
    divide by 1000
    if the material is steel then multiply by 7.85
    answer its grams
Add your answer to: "To use the command part massprop mass fraction of AutoCAD program How can I change the weight of the original?"
