Transient Heat Transfer Simulation in Solid Works
By Ravinder Saggam on 20 May 15:25 9 answers 4450 views 1 comment
Time dependent heat transfer simulation.
Problem statement: If a encloser having two or three heat plates which are emits heat varies with time and then air will blown over these heat plates to calculate the heat transfer taken place between air and heat plate.
  • Aled J Taylor
    Aled J Taylor over 4 years ago
    You need 'SolidWorks Flow Simulation' for this.
Add your answer to: "Transient Heat Transfer Simulation in Solid Works"
