trying to delete multiple lines at one time?
I am trying to delete a line but when I pick another line the first line clears and the only line picked is the last one I selected, why is this?
Hi, have you tried selecting the erase tool first, then in the command line it says specify entities, then you select all the lines you want to erase and then press enter. That should work. Or you can select all the lines and then press the delete button. But if you click the erase tool it will specify the entities you want to delete regardless if you have selected them already. Hope that helps!
