Tutorial: How to change dimensions of corrugated roof panel
Eliézer Brazil liked my 2.67″ x 7/8″ Corrugated Panels model but wanted to be able to change the dimensions to easily fit his specific models. I figured the easiest way to show him would be with a tutorial.
Here is how to change the width and length of my corrugated panels to suit your needs. This model is in inches and thus all dimensions of this tutorial are in inches. SW will convert dimensions for you so if you know you want a dimension to be 3 meters long just type 3m and it should convert it for you.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-change-dimensions-of-corrugated-roof-panel
