Tutorial - How to make a flexible hose in siemens nx
Another user wish - a flexible tube. I used a circular section surface, some expressions and lawcurves.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-make-a-flexible-hose-in-siemens-nx
Hi, yes it is more easy, but it is not the same - sorry. You "hose" will not contract and expand - you would just make a flexible tube. You notice the difference? That is the reason for using a law curve to control the contractions.
HI,
we can use a curve (Studio Spline) (i.e hose profile) as guide curve and a circular profile as section to make a hose and finally shell command to specify its thickness..
I think this will be much more easy..
