Missing feed
Tutorial, How to model a "Pneumatic 6 Cylinder Radial Engine" in SolidWorks!
By 2e740e6c on 27 Apr 17:44 24 answers 26 comments
The radial engine is a reciprocating type internal combustion engine configuration in which the cylinders "radiate" outward from a central crankcase like the spokes of a wheel. It resembles a stylized star when viewed from the front, and is called a "star engine" (German Sternmotor, French Moteur en étoile) in some languages. The radial configuration was very commonly used for aircraft engines before turbine engines became predominant.
http://en.wikipedia.org/wiki/Radial_engine
All parts are availible via Pneumatic 6 Cylinder Radial Engine
Parts:
1-Bearing Holder
2-Bearing Stand
3-Connecting Rod
4-ConnectingRobHub
5-Crankcase
6-Crankcase Cover
7-Crankcase Gasket
8-Crankshaft
9-Crankshaft Counterweight
10-Crankshaft Pin
11-Crankshaft Valve Crank
12-Cylinder
13-Cylinder Head
14-Cylinder Head Gasket
15-Flywheel
16-Piston
17-Piston Compression Ring
18-Stand
19-Valve
20-Valve Housing
  • Heather Hutton
    Heather Hutton over 3 years ago
    I used to overhaul R3350's. This is awesome! Thank you for your work.
Add your answer to: "Tutorial, How to model a "Pneumatic 6 Cylinder Radial Engine" in SolidWorks!"
