Tutorial: How to model a wide-chord fan in CATIA
This is a tutorial on how to model a high bypass turbofan engine fan using CATIA.
This is truly amazing work. Congrulations and thank you for this tutorial Chris
Simple, efficient and straight to the point !!!!!
how do you make the spiral strip mark on the cone??
Comments 2
Could you explain how you would add the profile shape to the blades when not just using "flat thickening" blades?
Would be super nice, if you could tell how you would add for example 3 different (NACA) profiles (root, middle, tip) in the same way you did it with the different angles of the blades.
Comments 2
