Tutorial: How to reuse trail file in PTC Creo Parametric and show design intent
Do you need to set diferent setting for your Creo Parametric session (ProENGINEER)?
You can crerate custom Shortcuts and customize your session :)
See my new video tutorial: http://youtu.be/7HDyV6slj6c
It is easy: You can crerate custom Shortcuts, create Trail file and customize your session :)
(Use the Trail file and All settings / Key sequences are used with program start)
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-reuse-trail-file-in-ptc-creo-parametric-and-show-design-intent
