Jaiprakash Pandey
Tutorial to design 3D AcME Bolt in autocad
Question by Jaiprakash Pandey
here is completed 3d bolt with 3d rendering and 2d layout
Austin R.
Answered on 30 Jun, 2014 07:35 AM
Hi Jaiprakash
In this tutorial I will make threaded ACME bolt in AutoCAD 3D, Dimensions for bolt is mentioned in 2D layout as shown below.
Follow steps as I have mentioned and you may view video attached with this tutorial for a clear description of each step, And don't forget to subscribe to my channel if you like my tutorials!!!
Step:1
Firstly make one cylinder of radius 4 units and height 30 units and other cylinder on top of first cylinder with radius 10 units and height 4 units, then make a helix starting from lowermost point of longer cylinder (cylinder with 30 unit height) with top and bottom radius 4 units 12 number of turns and height 30 units, follow image for detail.
Step:2
Make a new layer named layer 1 and assign longer cylinder to layer 1 and turn off layer 1.
Step:3
Insert block of ACME thread into drawing from insert block option of INSERT ribbon, You can download the thread block from here.
Step:5
Now turn layer 1 on and use subtract from Boolean operations to subtract thread profile from cylinder.
Hope this information help for you!
