want good and easy resource to learn kinematics in catia .......specially the advanced kinematics .........? thanks for help
as gear joint ...rack joint
this may help.
I am not the owner of this file just downloaded from a source online.
You learn about the type of constraints give you what kind of Joint between the links of a mechanism....
for Example if you are required to make a part to slide about a part in slot than you should surface Constraint and co inside constraint...
see some of my Uploaded files....
