what are different between feed and plung feed in cnc machines?
By mohamed khefacha on 24 Dec 10:07 3 answers 0 comments
what are different between feed and plung feed in cnc machines From a practical point of view
  • Harold
    Harold 11 months ago
    Plunge feed is on de Z Axel
  • Timothy Bellmar
    Timothy Bellmar 11 months ago
    It's the direction your tool feeds into the part and is different (rate) in that you are using two different cutting edges some end mills will not plunge if you can just use a drill.
Add your answer to: "what are different between feed and plung feed in cnc machines?"
