what is difference between positioned sketch & sketch in catia v5?
explain me in details...how it is advantable than using normal or regular sketch?
i want to know concept behind postioned sketch.....
thks in advance
Shortest description is that positioned sketch allow you to rotate and move sketch as you wish. Pictures added and details coming soon.
Answered with a tutorial: https://grabcad.com/tutorials/what-is-difference-between-positioned-sketch-sketch-in-catia-v5
We can able to swap & reverse the H & V directions in position sketch but it is not possible in simple sketch button...
The Sketch origin is defined with individually from positioned sketch and align with horizontal & vertical direction.
But in simple sketch the origin point only defined from the main Axis system pt..
How can convert the drafting file into pdf file in CATIA V5?
