what is gear module in solidworks library
There are numbers of gear module in SolidWorks gear library.. i can not justify what are they.!
Please help me out if anyone can...
3 Answer
A module of 1 means that a 10 tooth gear has a working diameter of 10mm, a 12 tooth gear has a working diameter of 12mm etc
A module of 2 means that a 10 tooth gear has a working diameter of 20mm, a 12 tooth gear has a working diameter of 24mm etc
thanks for replying, Aled J Taylor .
would you please explain me this from the attached image.. actualy I can't get the word "working diameter".
Is "working diameter" same as "Pitch Dia"..?
