what is mean by sub assambly & then how can i had sub assambly into the new assambly file
pls help me.....
A sub assembly is the same as an assembly.
you can add an assembly to a larger assembly the same way as a part and the assembly in an assembly is a subassembly.
i tried that but i con't achieve that............ can u give some example..................
Comments 2
