What is the best approach to design a gear system that can handle varying loads while minimizing wear and tear? Fahad Elahi Khan 18 Sep, 2024 08:09 AM The best approach for designing gear systems in SolidWorks that can handle varying loads while reducing wear. 1 Answer Omar El Arwadi Answered on 15 Nov, 2024 03:27 AM It depends on the material and the shape, gear ratio, size you want. There are books that give you the dimension and gear angle for that. Heat treatment improves the teeth of the gear. (Annealing)
