What is the difference between Global goals and Surface goals in Solidworks flow simulation?
What is the difference between Global goals and Surface goals in Solidworks flow simulation? To analyze drag force on a surface, which goal should be used?
In case you want to study results on a particular surface than use surface goals. In case the results for whole Assembly use Global goals.
