What is the use of "publishing command" in Catia?
Seeking for the "Publishing command" 's functionality.
The use of Publishing is to get an Association between TWO or more CatParts. Example: Profil-A.CatPart has a flange. You can publish the surface of the flange in Profil-A. you have another Different-Profil-B.CatPart with a mating flange. Now you can use the published flange in Part B. If you modify the flange in Part A it will also change in Part B.
I think I will make an tutorial soon at
www.youtube.com/catiatutorial
Greetings
Comments 2
