what is the use of Redefine in assembly constraints..??? please explain with example..
If we use constraints between 2 parts in assembly n if i right click on that particular constraint in assembly navigator I'll get this option.
My suggestion to U is....just try it.
This is the best way to master your 3D program, just explore the program, do things and in the process learn from it....trial and error!!
"nobody told the monkey how to peel a banana"
He first ate it with the skin, but by trying he learned that a peeled banana tastes much better....Same with CAD programs. (and all computer programs for that matter)
And before you try....save...so you can always go back to a previous state if the .... hits the fan....
