when my sketch is constraint coincidence with a 3d curve ...why still i have some gap between the curve and sketch??
please help me out
If you show us a picture, maybe we can write a comment for this problem.
I think these are not real gaps. It is performance problem from visual.
consider this case ...why the sketch is extended beyond the curves sir ??
Comments 2
it happens when.. the dimensions are very low. i mean around (1 - 25mm) it oftern happens in CATIA. but thats not the real error.. still you can use features
Comments 2
May be my idea will help you.
You can use the below setting in the Catia V5 to get the geometry. Just go to Tools --> Options --> Display --> Performance Tab and change the 3D Accuracy to the lowest value, (i.e). 0.01. as shown in the below Picture
