where can i get the detailed drawings of piston, connecting rod & crank shaft?
is there any sites that provides detailed skectchs?
This question has been asked many times before if you do a search in Q&A's 9 times out of 10 the question you have asked will be answered with a lot more peps getting a lot more answers :) :) :) which makes it a lot better for you and also saves you time on having to wait for others to get back to you with an answer........
There will be many links to engine plans that you require when you do that search in Q&A's but to get you started go here @ http://www.john-tom.com/
and I also see that Sudhir has gave you a link :) :) :)
Happy new year selvakumar
//Handshake
:P
https://www.facebook.com/MechanicalMachineDesign/photos_stream
Check this facebook page.. there are some.. :D
