Which Autodesk product will work best with converting Standard DWG file over to a STEP File?
By Milt Fitz on 30 Mar 05:01 2 answers 1 comment
Question for the group....Which Autodesk product will work best with converting Standard DWG file over to a STEP File? I'm working on a simple project and actually went on to Autodesk Discussions Group without much success. Any help or Ideas would be appreciated. Thanks, Milt
Added images
Square
  • Milt Fitz
    Milt Fitz over 3 years ago
    Stephen, this does not work with Regular AutoCAD. STL files will work if the 3D object is small. That being said, I have some larger files (wider the 12"sq) that a 3D printer is capable of working with so. I need to create "STEP" (Stp) files capable of working with a CNC machine. So...we are back to square 1 meaning:
    1.) Which Autodesk product(s) are capable of creating a STEP file?
    2..) Which Autodesk product is the best to work with?
  • Stephen Kingston
    Stephen Kingston over 3 years ago
    Any latest version of any Autodesk software would definitely do the job just fine. Which Autodesk product you use doesn't matter.
Add your answer to: "Which Autodesk product will work best with converting Standard DWG file over to a STEP File?"
