Which CAD software has an integrated 2D design module similar with SketchBook ?
Some design concepts are easier to draw using a tablet like Wacom.
Paul, take a look at SpaceClaim. It uses a simple 2D sketch environment and then you can pull your sketch into a 3D model. It is extremely powerful yet simple to use. The software is built around four functions: pull, move, fill and combine. Check out http://www.focalpoint-eng.com/SpaceClaimMain.html for a quick look.
