Which Catia V5 operations for machining a Torx (T30) screwdriver?
Hi,
i need to make machining simulation of a torx (T30) screwdriver and i`m not sure which machining operations to use. Also, machining would be performed on a 4-axis milling machine, something like this: https://www.youtube.com/watch?v=GFuvoSI5X9c. I was thinking about using T-Slotter tool and Groove milling operations. Even better solution would be operation like gear hobbing, so that part and cutting toll are both rotating.
Any kind of help would be appreciated! Thank you.
