Missing feed
Which dimensions are to be used from all these dimensions to draw this part in red ? and what does the different lines appearing means ( in orange )
By Gurmanpreet Singh on 06 Mar 05:56 2 answers 1 comment
I can't understand how to calculate right dimensions from all these dimensions. this is the link of the model that i want to practice. https://grabcad.com/library/desktop-fan-2/files/Creo%20Fan/blade.prt.13#
Added images
Square
  • Wilhelm Coetzer
    Wilhelm Coetzer over 2 years ago
    R23.9 + R29.21. THEN 2 FILLETS. BUT IT IS ACTUALLY NOT AS EASY AS ALL THIS. THE 2 RADII SHOULD ACTUALLY BE TO THE INTERSECTION OF THE FRONT FACE AND THE CONICAL FACES TAKING THE DRAFT ANGLE INTO ACOUNT FOR THE PLASTIC MOULD...
    I'D SAY R24mm AND R29mm WITH 2 FILLETS OF R2.5mm
  • Wilhelm Coetzer
    OH YES... AND THE LINES YOU SHOWED ARE JUST THE EDGES OF THE FACE. WHEN YOU RENDER, YOU SHOULDN'T SEE THEM. IT IS NOT A PHYSICAL EDGE.
Add your answer to: "Which dimensions are to be used from all these dimensions to draw this part in red ? and what does the different lines appearing means ( in orange )"
