Which produces better surface lofted surface or boundary surface
Anybody have any idea. It seems as though they give different results. the lofted the surface is more relaxed boundary surface gives you more flexibility but quality wise which one is better?
Boundary surface gives you a much better, smoother and more accurate controllable surface cuz it treats both directions equally but you'll find yourself using both for each different case and Boundary needs more curves and more steps so it kinda needs time moreover you can use a centerline loft which boundary surface can't make
