which type of flange bearing can afford axial load?
Types of bearings that can handle an axial loading are taper roller bearings and deep grove ball bearings. Taper roller bearings are fmainly used in applications with larger loading's. You will look for a flange bearing housing with a deep groove ball bearing fitted to it. If you know the radial and axial loads the bearing is to operate under this data can be used to select a suitable bearing. This link https://www.machinedesign.com/learning-resources/whats-the-difference-between/article/21831901/whats-the-difference-between-bearings will take you to a web page with some basic bearing information.
