Why always appears an error for me trying to insert the heat plate exchanger assembly drawn by your in my SolidWorks?
You should check if you export it i the correct file format
If you checked and it is in the file format that you usually use, try another format for there may me changes done to GRABCAD itself
Try changing the file name to pure english letters, maybe this will help
