Why does my Solidworks measuring tool give me fault dimensions
Sometimes I use the measuring tool to get dimensions from assembly but when I update the parts and try mate based on those new measurements the parts will not alight correctly. Why does this happen? tolerances in the settings
The measuring tool shows only two numbers after the point. The real dimension have actually much more numbers after the point. The system rounds off all the
other numbers and this is not the correct dimension.
