Why does the helical gears imported from Solidworks Toolbox for an assembly intersect.?
I am designing a helical gears assembly, for that I took helical gears from the TOOLBOX of Solidworks. Doing the assembly the teeth of gear and pinion are intersecting.
I took the following value as a design parameters:
Gear :
module = 2.5mm
no. of teeth = 53
Left hand design
helix angle = 25deg
pressure angle = 20deg
pinion :
module = 2.5mm
no. of teeth = 19
right hand design
helix angle = 25deg
Center-Center distance calculated to be 99.30401271mm
Can any one help me with this ? Also how to manually design the helical gears ?
Hoi Suraj,
maybe you can find your answer in the next link.
https://www.sdp-si.com/resources/elements-of-metric-gear-technology/page4.php
or attached pdf
Greetings,
Danny
