Why does the size of the STEP different from the regular files?
Sometimes the STEP file is smaller then the regular .sldprt file, however sometimes the size of the STEP file is much larger then the original file.... I don't understand why?
I believe it is the way SWX stores references, patterns and other entities. Whereas a STEP file only contains the solid geometry..
